Discussion Groups
Robot Structural Analysis
Active Contributor
skilak
Stress Skin Design
361 Views, 5 Replies
08-15-2013 01:40 AM
Hi there,
I am designing currently en enclosure (a box) implementing the Stress Skin Design. I have steel beams on the the roof supported by columns - top flanges all at the same level and 8mm aluminium plates bolted to it along every panel (panels are formed by roof beams) perimeter. Is there any method or option of how to offset the shell ?, it seems I cannot find it. I know I can offset the bars but offsetting the shell/panel would be much easier. Thank you in advance for your kind help.
Best regards,
Tomasz
Please use plain text.
Valued Mentor
tony.ridley
Re: Stress Skin Design
08-15-2013 04:45 AM in reply to: skilak
not possible. you could use compatible nodes or rigid links perhaps.
Active Contributor
skilak
08-15-2013 04:50 AM in reply to: tony.ridley
I though aboutt rigid links but if you mesh a panel then, for example, you will have 300 nodes for rigid links:smileywink: I am playing now with steelwork offsets to get expected results.
Please, could you explain "compatible nodes" ?
Cheers
Product Support
Rafal.Gaweda
08-16-2013 12:36 AM in reply to: skilak
Use rigid links.
Compatible nodes : check help
Rafal Gaweda
Product Support
Artur.Kosakowski
08-30-2013 12:41 AM in reply to: skilak
If you mesh panels in the same way in some situations it may be easier than you think it is :smileywink:
Artur Kosakowski
Active Contributor
skilak
09-04-2013 12:15 AM in reply to: Artur.Kosakowski
That one is brilliant:smileywink: cheers
