Could i design strap footings by using robot .. if i could .. how i can do it ?
Hi
You can connect the two single column footings by a bar or:
use panels for defining single column footings and connecting them by a bar.
Yes you can .
1- define your columns .
2- connect them by beam .
3- From geometry menu - additional attributes - bae elastic ground - new - elastic foundation coefficient ....... to define your soil layers .
then calculate .
1-But the beam which's conncet the two columns doesn't exposed to soil pressure !!
2- What about the shape of the two isolated footing , because the beam lie on the top of footing or between two isolated footing but not on the ground to avoid soil pressure >> by this way i will design the footing by hand calc ,, i want to design the foorting but robot
