In Provided Reinforcement, please see file attachment beam span 3, there are a Mf = 2996.3 kN-m that no correspond to my model.
How I can modify it?
I can’t access to loads table
@Anonymous wrote:Hello,
Probably a modelling glitch.
Does your model not show warnings or errors upon verifying meshes and going to analysis?
Looking at your model:
Diagram Seems fine here...
Yes, is not an analysis problem there aren’t any warning or error , the problem it’s in provided reinforcement module, please see M in spam 3 (attachment in first message in this post).
The values are given by the algorithm that combines results from offsetted rectangular beam and such width of panel that makes the resultant acxial force equal to 0 but I agree that these big values are suspicious. I'll investigate this situation but this is goint to take me a bit of time. You may also consider another approach: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Design-of-T-beams/m-p/4749299
