I was wondering whether anyone has had any experience with 'isolated nodes' - that in reality do not exist (ie are not in the nodes table but will give you the coordinates if you type the number into the node selector box and then are not at these coordinates).
I was also wondering whether anyone could shed some light onto the source of the RX instability when trying to analyse the attached model. I have a feeling that something is wrong within the data file for the model and hence the error with the missing node as I have tried to error check the model and it insists on throwing up more errors.
Rich
Open your model with dodgy nodes, press CTRL+A, then CTRL+C.
Open a new robot file.
Press CTRL+V
Voila! (should work)
Thanks for the tip...unfortunately it also seems to copy the odd missing node and strange errors across with everything else.
This is the calculation node generated at intersection of the indicated bars and the roof cladding edges (it will disappear when you delete these claddings). I think you can just ignore it.
