In case any admin get around to addressing this in the SP3 update -
If you create a model where stairs (represented by panel shells) go from storey to storey using the structure type "shell" then switch to "building" type to enable storeys, then switch back to "shell" again to enable 3D rotation and other functions the panels are allocated to storeys as you would expect. All fine so far.
But if you change stair panel shell elements from 1 storey to another the polylines are left behind. Consequently the shell panel elements which now reside in the new storey are no longer editable.
Scott
Please record the movie to show us what are you trying to do and how.
