Good afternoon,
I am sure this is an easy one for you 🙂
To edit a storey, I have RMC in 3D space and adjusted Z axis in dialogue box.
All elements have moved by the required 300mm but th e storey level as stayed at same z position. How do you make the storey level change too?
I have RMC to adjust the plan grids to move in X and Y Axis and this works OK!
Thanks!
Thanks Rafal,
The link does not appear to work at my end?
Another building storey query. I have modelled three stories, with an intermediate mezzanine level. When I go to XY 2 D plane at mezzanine, I only see the RC columns but do not see the walls that start at the level above. Any tips?
I have tried assigning all to all levels but does not appear to make difference!
Lee
message 1 -> click on attachment to download
File please.
Rafal,
Attached. As an aside, I cannot seem to get the plan views to show RC walls as solid, appear only to be as lines and columns as nodes. I have tried various display options but to no avail!
Thanks as always
Lee
Plan display of stories is not intended to make any "view" cuts by elements.
Top \ bottom walls edges are recognized only.
The same should be for bars : top \ bottom nodes of bars - but by mistake section shape is displayed in such case - need to be investigated by developers.
Please define elements and stories as they should be defined - from story to story.
