Hi
Please find the attached file. How can I limit stirrup spacing? (e,g. 250mm instead of 320mm)
Note: There isn't such option in Reinforcement Pattern Dialog
Solved by Artur.Kosakowski. Go to Solution.
Try to use the list with 25 cm as the last 'available' value.
