Steel vs. Aluminium design
4 REPLIES 4
jo2ny
2560 Views, 4 Replies
Hi all,
I'm having trouble designing a beam made of aluminium.
The beam in 5.02 m long, has two pinned suppports, several forces (KN/m - linear distribution) and a few combinations. Calculation is to be made in 2D XZ plane. Everything is ok so far. Calculation and diagrams look ok, but when i perform the steel/alum design i have a problem.
It seams that if the material is steel, the design verification is correct, but when i change the material to Alum, I get the internal axial value NEd = 0 and no buckling verification.
I'm probably doing something wrong....
Attached a picture and the rtd file.
Also I would like to ask what are the the values underlined with green in the picture. some coordinates?
4 REPLIES 4
Artur.Kosakowski
in reply to: jo2ny
Position of the verification point where the ratio is the highest.
Tension force in bar.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
jo2ny
in reply to: Artur.Kosakowski
Got it,
Thank you very much!
in reply to: jo2ny
Strange no one mentioned that aluminium member should be verified according to EN 1999-1-1 rules not EN 1993-1-1, which, the last time I checked, not implemented in Robot
Artur.Kosakowski
Can be if sombody decides to run such check in Robot (possibility rather than being told to do this) Smiley Wink
Artur Kosakowski
