In the attached example Robot only checks the shear force and not the moment capacity for the welded beam. If I change it to a standard profile it also checks the moment capacity.
The upper flange is stable against lateral torsional buckling.
Why isn't the check of the moment capacity for the maximum moment done for the welded beam?
Solved by Rafal.Gaweda. Go to Solution.
The ratio is displayed at the location where its value is the largest (x=0L) but you may force other verification point e.g. in the middle of the beam
And how do I do to force the check to another point? I have searched but I can't find it.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Steel-design/m-p/3340849
