I am trying to model a moment connection. I have selected a node and column and beam. The soft generated the default detail connection but it seems I cannot change anything e.g.. steel grade, bolts etc. Thanks in advance for your help.
Try to install the available SP first (in case they are not installed). Otherwise attach the rtd file.
