I was wondering how people use the timber/steel design module?
I can get a long list of elements, telling me which elements are failing and which aren't, but then i can't use that data to highlight the failing members, or even better show a maps on bars type visual showing percentage utilisation of each member. Is this possible?
Thanks!
Solved by Artur.Kosakowski. Go to Solution.
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autodesk-Robot-Structural-Analysis-Steel-des... and the attached pictures.
