Is it possible to export the information from the Member Verification Box? i.e. member number, section and ratio.. I can see how it can be plotted etc. but I'd like the actual data into excel if possible.
James
Solved by Rafal.Gaweda. Go to Solution.
or this macro http://forums.autodesk.com/t5/Robot-Structural-Analysis/Steel-Design-Reporting-API/m-p/3344437#M2935
