Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Spring / Damper within ROBOT model
3 REPLIES 3
StuartRogers
1399 Views, 3 Replies
I am looking into modelling a truss structure on brackets. Between the brackets and the truss structure there are elastomeric bearings.
Is it possible to model these bearings within ROBOT for a spectral analysis? Can I represent them with an element and specify their stiffness and damping?
Thank you for your help.
Stuart
3 REPLIES 3
No as the modal analysis calculates undamped vibrations only. This would be possible for THA analysis only.
Artur Kosakowski
How I can model a damper (buckling restrained braced frame) on RSA?
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tuned-Mass-Damper-TMD-creation-with-RSA/m-p/...
Artur Kosakowski
