I am looking into modelling a truss structure on brackets. Between the brackets and the truss structure there are elastomeric bearings.
Is it possible to model these bearings within ROBOT for a spectral analysis? Can I represent them with an element and specify their stiffness and damping?
Thank you for your help.
Stuart
Solved by Artur.Kosakowski. Go to Solution.
No as the modal analysis calculates undamped vibrations only. This would be possible for THA analysis only.
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tuned-Mass-Damper-TMD-creation-with-RSA/m-p/...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
