Hi,...
...is it possible to run Spreadsheet Calculator 2013 on MS Excel 2010 64bit? I'm trying to start it up but no luck,....
Regards!
Mark Martin
I am afraid not possible
I downgraded my ms office to 2007 version and realized that the spreadsheet calculator has no library. Should I download it from the subscription center or there's something wrong with ms excel settings?
Best regards!
Hi Rafal!
I'm trying to run Esop Help but it says "Acrobat Reader has not been installed", although I'm using Acrobat XI on a daily basis!?
Can you help me!?
Best regards!
Help was craeted in old technology not supported by Microsoft anymore.
Try this : http://www.microsoft.com/en-us/download/details.aspx?id=91
it may not help.
Hi Rafal,
...tried to do as you suggested and got the message "KB917607 already installed"!
Do you have some other tips?
Thanks!
English help files are located in :
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\RESC\Engineering\help\44"
go to folder and run *.htm file
"...Help was craeted in old technology not supported by Microsoft anymore.
it may not help."
Anyway... strange that help works OK on Spreadsheet Calculator 2012 and not OK for Spreadsheet Calculator 2013 on the same computer.
Assume that Spreadsheet Calculator 2013 was developed by Autodesk team not Microsoft :).
Windows 7 x64, Excel 2010 32-bit.
Developers are checking it. I will update this thread when I have some news.
