Spreadsheet Calculator 2012 - insert formula
7 REPLIES 7
Message 1 of 8
Romanich
1021 Views, 7 Replies
Hello there!
A problem occurred when trying to do one simple thing: insert formula with section info data.
Also I attached file. Thank you in advance!
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: Romanich
Most likely the section you try to import is not correctly recognized. Could you check if you have the same situation using e.g. HEA100 from one of the standard Robot section databases? Could you attach the Robot file you import bar 3 from please?
Artur Kosakowski
Message 3 of 8
Romanich
in reply to: Artur.Kosakowski
Dear Artur, thank you for your attention.
I found what the problem. This is bug. Just see picture:
Roman Zhelezniak
Message 4 of 8
Artur.Kosakowski
Please send me the rtd file. I would like to have a look at this issue. What is the section database you used - in case it is the user attach it as well. Thank you.
Artur Kosakowski
Message 5 of 8
Romanich
I attached rtd file.
Roman Zhelezniak
Message 6 of 8
Artur.Kosakowski
Please use H (height) and B (width) for concrete sections but D and BF for steel ones. This is how these section parameters are defined in Robot API.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 7 of 8
Romanich
Solution is manual correction of parameter?
Roman Zhelezniak
Message 8 of 8
Artur.Kosakowski
Currently yes, as only one type of the predefined formula is available in SC.
Artur Kosakowski
