Hello to all,
I was wandering what is the easiest way to model spiral stair slab (or car ramp) in ARSA. (see example pic)
Can you please share your ideas?
Thanks.
Solved by Romanich. Go to Solution.
Thank you very much for the video, I do every step in the video until I reach to the polyline command I pick the points using the grids on the screen (no coordinates) and there was nothing drawn by this command
I don't really know where is the problem, if i choose contour the lines appear but i choose line or polyline there is nothing on the screen.
my best regards
Have you tried reducing the graphic hardware acceleraction level?
Tools --> Preferences --> View Parameters
Reduce "Display acceleration" slider, restart Robot and then try it again.
Hi again.
I am stuck on with stairs again.
I need suggestion how to model this type of stairs (see figure).
I had the same problem, but with two stair runs.
Never figure out how to model it.
I aproximated it with three simple (straight) slabs.
Define panel1 . Define panel 2. Define panel 3 using corners of the previous ones as the reference points.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
@sergey.churilov wrote:
Yes, I am doing exactly the same. Two inclined straight slabs (for the staircases) and one horizontal straight slab (for the landing).
I am wondering if the modeling can be improved.
Won't this example give "distorted element"? i.e. panel 17 is not planar?
I thought you can't draw the bent panel like this and have reliable results?
Tony
No, why do you expect to have a distorted element for not flat panel with such simple geometry?
I think I solved it.
It took me more time and effort than it deserves for practical application and design, but I think this model is as close as possible to the real geometry.
I thought it is just the general rule in Robot, that plates should be planar.
Panels (including these which stand for plates) can be of any shapes. My assumption is that you mean the situation when you want to use cladding load distribution type.
