How can i generate spiral beam for the spiral slab (stairs) ?
it is attached / spiral slab .
As a chain of bar elements from one node to another.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Once you have the panel meshed, just draw bars from node to node along the edge.
Change the parameters of the mesh if you want the beam less linear.
Ensure the bar releases are fixed.
Done.
Go to: design tab - Steel Members design Options - Members/Groups Defenition
Click New, to create a new bar number
Add the bar numbers you want as the super bar into the, bar list.
Add name of super bar.
Change member type.
Click OK.
Read the help file regarding C. Groups (Code Groups), but your unlikely to need it at this stage.
