Discussion Groups
Robot Structural Analysis
Spacing Dimension Problem in Connection Design
130 Views, 1 Replies
07-09-2012 01:36 AM
Hi, when assigning a vertical spacing to the anchorage bars in a pinned column base plate design in connection design then Robot inputs an eccentricity from the centreline of the girder and not an anchorage spacing. The anchor studs remain at a constant spacing of 115mm.
Do you have any idea why this is happening? How do I correct this problem.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Spacing Dimension Problem in Connection Design
07-09-2012 02:25 AM in reply to: Sambrook
Please download and install SP for Robot 2012.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
Artur Kosakowski
