Hi.
Im just curious about how to model a sloped beam with the possibility to slide horisontally on top of crossing beam, but not be able to deflect vertically? Ive made a sketch of the situation. Ive tried with releases, but do I need to use compatible nodes?
Solved by Artur.Kosakowski. Go to Solution.
Either will do. You can release UY for the horizontal beam.
