Hello, I'm working on roof truss design and now facing a trouble 'bout instability which is the slenderness check of steel sections. 2 attached images show my doubt about kL/r ratio which is extremely high. From images i got the values of ky, Ly and ry which are 1.0, 11.0 m. and 6.0 cm respectively. Hence ky*Ly/ry should be 183.33 isn't it?
So how can i solve it?
Thank you
Solved by Artur.Kosakowski. Go to Solution.
Please check if the value of axial force is not above the critical level. If this doesn't answer your question attach the file please. Thank you.
Thank you for reply. So, i attach the file and hope you will solve my ploblem. I found something in the verification formula when i take a manual calculation follows that formulas. Some parameters are zero which make errors in that formulas.
Pls figure out what i found.
Thank you for help.
Here is the link (Can't attach because file size is large)
Please download and install SP4 and HF 5 for Robot 2013 from:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
Mind the select the correct files (Robot Professional vs. Standard and 32 vs. 64-bit).
Hi Artur,
I'm facing the same issue now with Robot 2019. What should I do?
