Hi, how can reinforced the floor with required on robot and how can update the reinforcement in revit structure - no extension for slabs in revit -????
and
can I update the whole reinforcement in the revit structure after calculating the required reinforcement using robot???
Solved by Artur.Kosakowski. Go to Solution.
How I can update the reinforcement in revit structure ,I mean the all column , beams and foundation together,
because after doing the update model using extension, then I update the each member alone which not efficient
help please, thanks
Could u help me, how I can do the update slab using ASD file ????
regard
i use these but i didnt have the update reinforcment, the model shoud not have any reniforcmeint which created from extention???? or this is not make change ??
You should generate provided reinforcement in Robot first.
