Slab reinforcement
5 REPLIES 5
pevelor
947 Views, 5 Replies
Slab reinforcement
Hi.
I have a plate with some depressions. I have modelled these depressions as seperate plates with the correct thickness (100mm). In these areas, I only have space for one layer of reinforcement, and I am forced to choose the option "compression/tension" to be able to use membrane reinforcement.
How will this effect my results, and is there a smarter way of analizing this?
Kind regards
Peder
What are the differenceReinforcement type
5 REPLIES 5
Artur.Kosakowski
in reply to: pevelor
For slabs you cannot use this option as it disregards bending.
Artur Kosakowski
Hi Artur,
Will it disregard bending for all slab types i.e. it will only work for columns/beams?
Can you please expand on that answer? For a floor plate model with shell elements and the reinforcement type is "RC floor" is it not possible to use "bending + compression/tension" as illustrated above?
Thanks in advance,
Jesper
Jesper
This is setting for RC panels only with such reinforcement type assigned
?????? More precise question please.
There are many predefined labels in Robot, you can not edit them. If you want to make any change - just save such label under new name and assign to object(s).
Rafal Gaweda
Hi Rafal,
Thanks for you reply, I'll try to be more clear in this response.
Arthur mentions above that "For slabs you cannot use this option as it disregards bending.". The option I believe he is talking about is using the option of calculating reinforcement for shells accounting for bending + compression/tension for slabs. My question is then, what type of members can it be used for then?
If I have a plate model with shell elements and the reinforcement type is "TSL", where "TSL" is a user defined reinforcement type where I have specified using "bending + compression/tension" as illustrated above, is Artur then saying that this will not work as it will disregard bending? That is how I read his reply.
Jesper
It depens on loads \ forces in panels you want to consider in design. The choice is yours.
In general:
- slabs act mostly on bending so you should use "simple bending" ; in case you want to consider axial forces "bending + compression/tension"
- walls act mostly on compression \ tension so you should use "compression \ tension" (selecting this one is able to set one layer reinforcement in panel) but in case of bending in them use "bending + compression/tension"
etc
"For slabs you cannot use this option as it disregards bending."  - I understand this as "bending must be \ should be used for slabs".
Rafal Gaweda
