has anyone encountered similar problem, as i run provided reinforcement verfication, i get this message:
"Zones do not cover all the regions where reinforcement ir required"
I get this message with manual reinforcement placement also. Its so frustrating 🙂
I'm not sure if I understand this issue correctly. Looking at the picture my assumption is that there are no zones defined. Could you attach the file with the zones you defined manually?
Sorry, i forgot to run reinforcement calculation, before verification. Now everything is fine. Thanks for response.
