Discussion Groups
Robot Structural Analysis
Valued Contributor
CKDDIZ
Accepted Solution
Slab punching check
267 Views, 3 Replies
02-28-2013 06:37 AM
slab punching check for the slab shown in the pictures.
The difference from pictures 1 and 2, is that the columns angle changes by 90 degrees, and that affects the punching perimeter of the edge and corner columns, since the slab continues over the edge columns X-direction 0.6m and Y-direction 0.3m
Please use plain text.
Product Support
Artur.Kosakowski
Re: Slab punching check
02-28-2013 06:46 AM in reply to: CKDDIZ
Attach the rtd file please?
Artur Kosakowski
Valued Contributor
CKDDIZ
02-28-2013 06:48 AM in reply to: Artur.Kosakowski
the file.
Product Support
Artur.Kosakowski
02-28-2013 07:08 AM in reply to: CKDDIZ
The display (orientation of the panel) in the RC Design viewer can be different than the top view of the model and depends on the local X of the panel. As far as I can see the columns are 'exported' as they should be. You can check looking at the numbers of nodes displayed in the brackets (2) - (4) etc.
Artur Kosakowski
