348 Views, 1 Reply
Slab edge meshing
I have a 6-sotrey RC building 10m x 20m. The slab edged are slightly offset from the walls and requires a very fine mesh to run (0.22m) without showing the 'kinematic constraints' error everybody seems to get. This causes the program to run very slow when performing a seismic analysis as I believe the load is shared between all the nodes at floor level.
Is there a way of easily adjusting the slab edge or auto-detecting they are together? Prefereably without revisiting the Revit model which was hard enough to align in the first place.
1 REPLY 1
Artur.Kosakowski
Try to define structural axes at the location of the walls and use the detailed correct option. You may also indicate the plane by 3 corners of a wall. The idea is to match slab edges with walls.
For the meshing parameters and problems:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Warning-after-Structure-Verification/m-p/320...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
