To whom it may concern.
Just wondering if I can get some help on this matter.
I've been able to produce a slab reinforcement drawing which then obviously tells me all I need to know about the reinforcement groups such as the number of bars, length and spacing. But with a few of the groups some of the information is followed by an asterix symbol. (An example JPG file has been attached). This usually follows the length (as in the example) or the spacing and I was just wondering what it meant. Is it showing an error?
Any help would be greatly appreciated.
Regards
Andrew Milner
Solved by Artur.Kosakowski. Go to Solution.
The average length of a group of rebars with variable lengths (e.g. for a triangular slab).
I'm not sure what you mean by the symbol of rebar. Could you give me more details (picture) ?
Hi
Choose Analysis>> Drawing parameters. In the dialog box, choose Reinforcement table. Please find the attached file.
