Hi to all.
Is it possible do model a pipe with shell elements that intersects with a rock mass that has been modelled with solid elements?
The shell pipe is necessarry in order to design the pipe with the applied pressures?
Thanks.
Solved by Rafal.Gaweda. Go to Solution.
Yes, I have tried. Indeed it is possible, but one has to be very careful with mesh incoherence problems.
I think I have not used ACIS. The option 'Define by default in a Solid Modeler format' under Preferences>View Parameters>Solid Modeler was switched off. Is this the correct way to activate ACIS?
