Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Shear considered in column calculations
9 REPLIES 9
Message 1 of 10
899 Views, 9 Replies
I turn on "Shear considered" when I calculate a column, but then get the message "Unsatisfactory load capasity of the column." When I look at safety factors it says VRd/VSd = 0,00, see the attached file. I guess that means VRd = 0 kN, that again means that the column have no shear capasity at all, this must be wrong?
Eirik
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
File please
Rafal Gaweda
Message 3 of 10
in reply to: Rafal.Gaweda
Here you go.
Message 4 of 10
Artur.Kosakowski
Try to force the use of 32mm bars as main reinforcement.
Artur Kosakowski
Message 5 of 10
OK, that solved the problem. But isn`t this a bug? If I set the corner bars diameter to "Auto", shouldn`t Robot figure this out self?
Message 6 of 10
Artur.Kosakowski
I have checked on the pre-release version of  Robot v.2014 and it does Smiley Happy
Please note: Our quality assurance teams may need to reschedule some fixes. Please rely on the above timeline information as a guideline only and not a guarantee. We appreciate your understanding in this matter.
Artur Kosakowski
Message 7 of 10
in reply to: Artur.Kosakowski
Love to hear that, keep up the good work.
Message 8 of 10
I'm having the same issue, whereby Vsd=0.00 and it doesnt really matter what reinforcement I put in.
The 'bug' is still persistent in Robot 2015...it seems.
Is there any quick way around it?
I've got quite a big file with all the rc design and a lot of combinations, so trying different reinforcement arrangement is very time consuming.
Message 9 of 10
Could you attach the file with the column where you have such situation. To reduce the size of the model you can save the part of the model which contains the column as a substructure (mind to have both the model and the column calculated before saving a substructure).
Artur Kosakowski
Message 10 of 10
Substructure model available @ https://www.dropbox.com/s/k5ijlnzwtvosstx/column.rtd?dl=0
