Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Selected nodes numbers
2 REPLIES 2
jo2ny
769 Views, 2 Replies
Hi guys,
I'm having trouble with some nodes. I want to select all pinned nodes, and view them in a new window.
I used special selection, and selected all the nodes with the pinned attribute.
Ok so far.
The problem is that in spite the fact they are selected, and i have the options "node numbers" and "display attributes only for selected objects" turned on, these nodes don't show up.
I've done this in other models but now it just doesn;t work.
Any ideas why?
I also noticed that if I select a bar on which these node are, the end nodes show up (the numbers and the pinned triangle symbol), while the ones in the middle of the bar don't.
Thanks in advance.
2 REPLIES 2
Artur.Kosakowski
in reply to: jo2ny
What is the model type you have - is it a building? If yes check if you have story filter applied on the display.
Artur Kosakowski
jo2ny
in reply to: Artur.Kosakowski
Yes, it was the story filter.
Thanks!
