I have defined several load cases including seismic ones. When making automatic combinations the first time, all went well. However, after sending to Revit for a few ajustments and updating back to Robot, the seismic cases are no longer included in combinations. Why could this be?
Thanks!
Hi
Any chance to upload the files or send them to us?
On my test model everything works fine.
The file is pretty huge, so I 'm not sure sending is easily accomplished. I've managed to include them by redefining the seismic cases, which is not a big problem. I was just wondering if there was some kind of "thing" with seismic cases that I didn't know about.
Did you also try the back-and-forth-to-Revit part?
I have checked manual combinations but in case of automatic comobinations the relations are misssing:
Set them again as shown below
or generate manual combinations basing on automatic combination generator (of course set \ check relation first):
