Discussion Groups
Robot Structural Analysis
Active Contributor
Seismic example
410 Views, 7 Replies
06-05-2012 03:59 AM
I am trying to solve the above example ( attachment).
Seismic analysis consist of EC 8, acceleration coeff.0.35, zone B and behavior coeff. 2 damping 5%
the modal analysis and deformations are correct, but the reactions for the seismic case do not correspond to the example.
I don't know where the mistake is?
Thank you
Please use plain text.
Active Contributor
jenyzosin
Re: Seismic example
06-05-2012 05:35 AM in reply to: alb2
You need to put the combination sign "1" (in your case) and then you gone have the right reactions.
There's a fine line between genius and insanity. I have erased this line - O.L.
Product Support
Re: Seismic example
06-05-2012 05:42 AM in reply to: alb2
Sax is different in your program than in robot specrtal coeff (for both modes).
Have you checked code book yet?
Rafal Gaweda
Active Contributor
Re: Seismic example
06-05-2012 05:50 AM in reply to: Rafal.Gaweda
Can you please be more specific?
Product Support
Re: Seismic example
06-05-2012 06:17 AM in reply to: alb2
Have you checked with EC 8 code book the way \ correctness of Sax calculations for given data for each mode?
EC8,  Part 1,  3.2.2.2 Horizontal elastic response spectrum -> calculations of Se(T)
Rafal Gaweda
Active Contributor
Re: Seismic example
06-05-2012 07:43 AM in reply to: Rafal.Gaweda
In case Sax is not correct, how can it be change for each mode?
Product Support
Re: Seismic example
06-05-2012 07:58 AM in reply to: alb2
1. Case 2 is model case so N/A results are correct
2. These values are calculated by program. Not possible to change thm in Robot. Maybe in your program...
Rafal Gaweda
Active Contributor
Re: Seismic example
06-05-2012 08:14 AM in reply to: Rafal.Gaweda
Probably will be a small difference in spectra values between the 2 program. I am guessing
Thank you anyway for your support
