Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 8
677 Views, 7 Replies
Seismic example
I am trying to solve the above example ( attachment).
Seismic analysis consist of EC 8, acceleration coeff.0.35, zone B and behavior coeff. 2 damping 5%
the modal analysis and deformations are correct, but the reactions for the seismic case do not correspond to the example.
I don't know where the mistake is?
Thank you
7 REPLIES 7
Message 2 of 8
jenyzosin
You need to put the combination sign "1" (in your case) and then you gone have the right reactions.
There's a fine line between genius and insanity. I have erased this line - O.L.
Message 3 of 8
Rafal.Gaweda
Sax is different in your program than in robot specrtal coeff (for both modes).
Have you checked code book yet?
Rafal Gaweda
Message 4 of 8
in reply to: Rafal.Gaweda
Can you please be more specific?
Message 5 of 8
Rafal.Gaweda
Have you checked with EC 8 code book the way \ correctness of Sax calculations for given data for each mode?
EC8,  Part 1,  3.2.2.2 Horizontal elastic response spectrum -> calculations of Se(T)
Rafal Gaweda
Message 6 of 8
In case Sax is not correct, how can it be change for each mode?
Message 7 of 8
Rafal.Gaweda
1. Case 2 is model case so N/A results are correct
2. These values are calculated by program. Not possible to change thm in Robot. Maybe in your program...
Rafal Gaweda
Message 8 of 8
Probably will be a small difference in spectra values between the 2 program. I am guessing
Thank you anyway for your support
