Discussion Groups
Robot Structural Analysis
andlund
Section definition
152 Views, 3 Replies
10-31-2012 06:14 AM
I have done a new section with section tools. I have made a beam with a radius representing the welding between the web and flange, making it look like i HEA but with other lengths and widths. When I then run a calculation I see in the steel design view that a member stability check is not preformed. I wonder what is wrong and how to solve it?
Anders
Please use plain text.
Product Support
Rafal.Gaweda
Re: Section definition
10-31-2012 06:21 AM in reply to: andlund
What is the shape type of this section in database?
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/New-profiles-in-Section-database/m-p/3454604...
Rafal Gaweda
andlund
10-31-2012 07:19 AM in reply to: Rafal.Gaweda
I'm using an I-section, the sixths below the question mark, I have another question. I have different width of the upper vs the lower flange but when i choose the I-section, new values of properties appear. Do I need to fill these ones out. Attached is i picture.
These are the properties if you wanna compare:
[mm]
Upper flange:
Width=550, thickness=22
Lower flange:
Width=350, thickness=15
Web=
Height=913, thickness=12
Product Support
Rafal.Gaweda
10-31-2012 09:08 AM in reply to: andlund
Whatever you select under question mark button while saving please open database, change section SHAPE TYPE  onto 95 and fill proper data in table part of Section Viewer window to get all of them (correct)  on display.
Results:
Rafal Gaweda
