Section builder workflow
3 REPLIES 3
pevelor
728 Views, 3 Replies
Hi
I am a little unsure how the section builder module works.
I want to define a new profile which I am able to under section definition. From here I save the profile to my database.
When I run structure analysis, the profile is discretized and I now see the stresses.
1. Do I have to do the stress analysis before saving to database?
2. Can I apply loads to for instance an angle to controll the moment capacity?
       -  If possible, how is it done?
       -  If not possible, what is the point of the stress analysis
Kind Regards
Peder
3 REPLIES 3
Artur.Kosakowski
in reply to: pevelor
No, you don't.
This is the Steel Design module 'responsibility'.
In the Section Builder module this is just the auxiliary tool that allows you to check stress distribution without using this section in a model. Of course you can access the Stress Analysis module 'from' the model too and import the section together with its internal forces later on to check stress distribution along and across the section.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
emre.63
in reply to: Artur.Kosakowski
HELP !
How to make a new section (in Section Builder) in order to create variable inertia bars ?
(Impossible since the creation of the bar in Geometry tab)
Rafal.Gaweda
in reply to: emre.63
