Hi
Im trying to import a dxf file to define a section i require, however when i standardize the section and calculate the results, it stops with Area discretization. and does not complete the calculation of section properties. I have even left my computer turned on over night and still it keeps showing me Area discretization.
I have attached the sections( dxf files) i want to use for my calcs. kindly help me out and help me resolve this issue asap cheers
regards
matt
What do you want to standarize?
This is my understanding of this section - nothing overlapping = nothing to standarize.
Matt
As concerns section 157 : Delete second opening contour before calculations
The units aparently change from 130mm as per original to 1300mm when i open the section file you sent me.
Well as you had told me to change from "cm" to "mm" in the .sec file. I did change from cm to mm but still the section shows up in cm scale. ?
