Dear sir
i defined new section HHH & saved it to database , when i insert it into my model we have problem (kindly find pic 1)
best regards
Solved by Artur.Kosakowski. Go to Solution.
Have you selected the section type saving it in the user database?
OK sir i selected the section type .but dim 220*220*20 but i filled all required dimension =1
but when i insert section in model i have good properties & results. just i want to now.
what dimension must i fill in pic2 ( kindly find attach file)
regards
The section properties are taken as calculated yet the selection of the section type determines the verification path (which formulas are to be used) and section class (slender, compact etc.) therefore you should enter the sizes of flanges (total thickness) and web. In the name you should fill in the first two fields. You can leave the other empty or type some numbers there as well.
BTW: try to select the whole section (CTR+A) and press the indicated icon before calculating the properties. In general that should be done for all sections build with parts.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
thank you ... but there is something unclear ...kindly find pic 3
and i have problem with anther section kindly find pic 4.
http://www.4shared.com/zip/iNRkz9QF/pic_34.html
regards
Pic 3:
The name is entirely up to you e.g. UCC203x203x100 or UCC203x0x10
I would enter:
h=181.2+2*(25+20.5)
tf = 25+20.5
tw and b as for the original section
Pic 4:
The question you need to answer is how would I verify this section (as I section, pipe or perhaps a structural tube) and decide on the best matching one.
