Hi!
I get this result properties while using section definition module to analyze the section on following picture.
Does anyone knows how elastic flexural modulus get higher than the plastic flexural modulus??!...
Dirgs
This section should be calculated rather as thin walled section - 0,5cm thickness on some parts comparing to ~6m length.
Algorithms must be checked by developers 😞
No problem. Hope it helps to improve the Section Module, seems there have not been major improvemens for for quite some time.
