Section Definition Analysis
5 REPLIES 5
Dirgs
665 Views, 5 Replies
Hi!
I get this result properties while using section definition module to analyze the section on following picture.
SD2.PNGDoes anyone knows how elastic flexural modulus get higher than the plastic flexural modulus??!...
Dirgs
Tags (1)
5 REPLIES 5
Rafal.Gaweda
in reply to: Dirgs
Send us sec file to check.
Rafal Gaweda
Dirgs
in reply to: Dirgs
Here it is Smiley Wink
Rafal.Gaweda
in reply to: Dirgs
This section should be calculated rather as thin walled section - 0,5cm thickness on some parts comparing to ~6m length.
Algorithms must be checked by developers 😞
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
If you have please send us dxf file with this section.
Rafal Gaweda
Dirgs
No problem. Hope it helps to improve the Section Module, seems there have not been major improvemens for for quite some time.
