The easiest way is to define 2 analogous load cases - one linear and another with second order effects. Second order effects are visible when comparing results for them.
Another possibility is to activate for non-linear load cases to save results after each load increment. Using these results the advanced diagrams can be displayed showing for instance force-displacement relations when incrementing the load. Increasing the number of load increments results in improving quality ("smoothing") or these diagrams.
See the attached screen capture showing what to modify and the example of diagram.
If this post answer your question please click "Accept as Solution".
It will help everyone to find answer more quickly!
Best regards,
