Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Scheme for steel plate calculation (baseplate and column connection)
0 REPLIES 0
Message 1 of 1
Jummybear
1590 Views, 0 Replies
Question about the right scheme for steel plate calculations. Its clear that the most accurate results i will get from 3d scheme/model, but it tooks a lot of time to create the right calculation model in 3d. So I use as a structure type 2d plate or shell design. Now i have some simple questions:
1. How accurate the obtained results if i do it in 2d, not in 3d model?
2. How should i define the loads and supports: anchor bolts as support points and profile contour as a linear load or contrarwise anchorbolts as a point load and profile contour as linear supports? This 2 schemes gives me different results, especially if we have not symmetrical model (take a look to attached picture)
Its all simple and easy if we have axial load Nsd for example, but when column is loaded with a banding moment the load definition as a point loads on anchobolts is still possible (2 points with "+" mark and 2 with "-"), but linear load definition is not so easy in such case, especially if your structure/model is not symmetrical.
Can you give me an advice or some comments about that? Probably there are some more way to calculate such steel base plates...
Thx.
PS 2 simple examples ataached to the mesage, symmetrical and unsymmetrical models.
0 REPLIES 0
