After calculations , RSA save results combinations and results .
these step takes a long times for big models.
in my case , it seems that progress bar is stuck at 94% for more than 30 min ( may be more ) and the remaining time is growing (!) .
i stoped and rerun calculation two times on two different machines ; but have the same pb ( 94%...).
How can i avoid that ? is there any explanation?
thank you.
Solved by Rafal.Gaweda. Go to Solution.
Wait till the end of progressbar = till this windows is closed.
Ok.
it means that there is no problem at this stage , only mater of time ?
Thank you
