Same Reinforcement in all column
23 REPLIES 23
Message 1 of 24
bparmar900
813 Views, 23 Replies
Hi All,
I am a new user of RSA 2013. When I am going to do design structure, It will give same reinforcement for all storey.
For the top most stoey it will give same einforcement as it will give for the bottom most storey.
I have given same load on all storey. I am using Indian Corcrete Design Code IS 456:2000 for design concrete member. Material is M25 for all.
Thanks in advance.
BParmar
SVNIT
23 REPLIES 23
Message 2 of 24
Rafal.Gaweda
in reply to: bparmar900
MInimum reinforcement?
If it is not the case please send the model.
Rafal Gaweda
Message 3 of 24
bparmar900
in reply to: Rafal.Gaweda
Yes minimum reinforcement.
Message 4 of 24
bparmar900
I want minimum reinforcement in all column and beam.
The result which i get by design what is it exactely?
Plz help me on this.
BParmar
SVNIT
Message 5 of 24
Rafal.Gaweda
What do you mean by "I want"?
Program calculates reinforcement. If required reinforcement is less or equal minimum given by the code - the minimum is used, otherwise calculated amount of reinforcement.
Rafal Gaweda
Message 6 of 24
bparmar900
Message 7 of 24
bparmar900
Thnx RG. You are right but my qustion is for all storey.
In my model I have 7 storey building and in every column same reinforcement is there.
As I understand Bottom most stoey consume more load so it has more moment. Due to this it should have more reinforcement compare to top storey.
Please Guide me.
Provide me your mail so I can send my model.
BParmar
SVNIT
Message 8 of 24
Rafal.Gaweda
Please Guide me.
I will do if you send the file.
Rafal Gaweda
Message 9 of 24
bparmar900
Hi
Message 10 of 24
Rafal.Gaweda
Message 11 of 24
bparmar900
Please find the link for model.
Please give me solution asap. I badly need this.
Thanks in advance.
https://www.dropbox.com/s/o6mh26ywbjwj0nf/Check1.rtd
Message 12 of 24
bparmar900
Please give soluton asap.
Message 13 of 24
bparmar900
Message 14 of 24
Rafal.Gaweda
Example movie: http://screencast.com/t/cnmgfqp3CY4
Rafal Gaweda
Message 15 of 24
bparmar900
Thank you very much for your support. Can I have the exact method to design column, Beam, slab, etc...?
Still I understand that, we can design from Menu Bar > Design > Required reinforcement of RC beams / Columns.
And we have to set parameter from Menu Bar > Design > Required reinforcement of RC beams / Columns - options.
Now can you explain what is that for?
If you have the way to exact design, please provide me.
Thanks once again.
BRajput
Message 16 of 24
Rafal.Gaweda
Slanted columns, inclined beams or if you want reinforce elements by your own using required reinforcement area only
Rafal Gaweda
Message 17 of 24
bparmar900
I want exact method tutorial to analyze and design a structure.
Please suggest me a good tutorial. Earlier tutorial on robot 2010.
I fine robot 2013 different den this.
BRajput.
Message 18 of 24
Rafal.Gaweda
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13093279
or in search of our forum write tutorial
Rafal Gaweda
Message 19 of 24
bparmar900
I already have this tutorial and I go through it.
Can you have any document related to robot 2013 or newer version.?
Please explain me to under stand the difference between required reinforcement and provided reinforcement.
At what time should I use for design for which task?
Please finf attachment.
I want to know the exact meaning of this two term related to this software.
Message 20 of 24
Rafal.Gaweda
Required reinforcement - amount of reinforcement (reported as area (value)) required by the national code to reinforce element
Provided reifnorcement = required reinforcement + all geometrical requirements given by the code (minimum spacing, minimum diameter etc) and as a result program generates real rebars in real positions
in RC Beam , Column or Spread footing module the first step is calculated in a "background" so as  final results you get real reifnorcement
For RC Slabs you have to  \ can do it in two steps : first calculate required reinfoecement then import designed panel to Provided reinforcement module
If you want to calculate only required reifnorcement for bar elements you may use mentioned earlier option
Rafal Gaweda
