Discussion Groups
Robot Structural Analysis
Active Contributor
bparmar900
Same Reinforcement in all column
316 Views, 23 Replies
03-27-2013 08:24 PM
Hi All,
I am a new user of RSA 2013. When I am going to do design structure, It will give same reinforcement for all storey.
For the top most stoey it will give same einforcement as it will give for the bottom most storey.
I have given same load on all storey. I am using Indian Corcrete Design Code IS 456:2000 for design concrete member. Material is M25 for all.
Thanks in advance.
BParmar
SVNIT
Please use plain text.
Product Support
Rafal.Gaweda
Re: Same Reinforcement in all column
03-28-2013 01:02 AM in reply to: bparmar900
MInimum reinforcement?
If it is not the case please send the model.
Rafal Gaweda
Active Contributor
bparmar900
03-28-2013 07:48 AM in reply to: Rafal.Gaweda
Yes minimum reinforcement.
Active Contributor
bparmar900
03-28-2013 09:26 PM in reply to: Rafal.Gaweda
I want minimum reinforcement in all column and beam.
The result which i get by design what is it exactely?
Plz help me on this.
BParmar
SVNIT
Product Support
Rafal.Gaweda
03-29-2013 01:55 AM in reply to: bparmar900
What do you mean by "I want"?
Program calculates reinforcement. If required reinforcement is less or equal minimum given by the code - the minimum is used, otherwise calculated amount of reinforcement.
Rafal Gaweda
Active Contributor
bparmar900
04-01-2013 03:16 AM in reply to: Rafal.Gaweda
Active Contributor
bparmar900
04-01-2013 03:20 AM in reply to: Rafal.Gaweda
Thnx RG. You are right but my qustion is for all storey.
In my model I have 7 storey building and in every column same reinforcement is there.
As I understand Bottom most stoey consume more load so it has more moment. Due to this it should have more reinforcement compare to top storey.
Please Guide me.
Provide me your mail so I can send my model.
BParmar
SVNIT
Product Support
Rafal.Gaweda
04-02-2013 12:42 AM in reply to: bparmar900
Please Guide me.
I will do if you send the file.
Rafal Gaweda
Active Contributor
bparmar900
04-19-2013 06:03 AM in reply to: Rafal.Gaweda
Hi
Product Support
Rafal.Gaweda
04-19-2013 06:05 AM in reply to: bparmar900
