Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
STEEL DESIGN - INSTABLE SECTION - SLENDERNESS - Beam design under ULS
5 REPLIES 5
1294 Views, 5 Replies
I have generated 3D frame using RSA 2013 professional. When i verify the rafter beams under ultimate limit state, the results shown are instable. And when optimized under ULTIMATE it provides very large dimension beams. whereas when i used SERVICEABILITY METHOD, it is fine.
Please help me, how to verify beams in 3D generator.
Please find attached 3D design file
Kind regards,
Ajmal
5 REPLIES 5
I ain't able to attach rsa file, please help me
find result snaps for reference
why can't i design beam under ULS
Artur.Kosakowski
ULS and SLS check are two different verifications,. As far as I can see the problem you have got is the exceeded slenderness limit. Looking at the buckling Z part you can see that unrestrained buckling length for 140 section is over 14m which way  too long weak the axes if this section. Have you set the buckling parameters correctly?
Artur Kosakowski
I haven't set the paramters. I am a learner, student. how to set, will you please help me
Ajmal
in reply to: Artur.Kosakowski
The beam length is 7.11 m
bay width is 14 m
Artur.Kosakowski
Assuming it is a 2 span beam then either you set buckling Z (and LTB) coefficients as 0.5L or you should define an intermediate restrain at this point and then set these coefficients as 1.0L  for each of the spans.
Artur Kosakowski
