Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Running out of Memory
3 REPLIES 3
LiveMike
1051 Views, 3 Replies
Shell Model will not Mesh
I have a simple Robot model (attached) that hangs up and runs out of memory when it tries to mesh.
(I am running Robot Structural Analysis Professional 2013 version 6.1 with the latest service packs on Windows 7 with service pack 1, 64 bit.)
Tags (3)
3 REPLIES 3
Rafal.Gaweda
in reply to: LiveMike
348m x 392m wall with 1cm mesh .....
Do you really want to mesh it like that ?
I guess you will need 12 GB RAM memory, at least.
Rafal Gaweda
t.sautierr
Scale your model, as Rafal said your working in meter and I think your structure is set for cm ... so your pannel is 348 cm or 3.48m. Even with this dimension the size of the mesh is very small, it depends what your are studying but for general study ..... 0.2-0.3 is fine .... (1/10 the dimension of your model)
LiveMike
in reply to: Rafal.Gaweda
Thank you.  What I modeled was only a million times larger than the anchor plate I intended to model.  Heh, heh.
