Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Rounding up coordinates (API)
46 REPLIES 46
Message 1 of 47
Rafal.Gaweda
8907 Views, 46 Replies
I am attaching small addin (private, not ADSK) for rounding up coordinates in Robot
You can add it to add-ins menu:
- as dll (the fastest method of getting results from robot) basing on dll_1.zip from this thread starting from point 13
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Creating-DLL-for-API-and-making-it-available...
- as exe
or by running exe
It seems to work OK.
Rafal Gaweda
46 REPLIES 46
Message 41 of 47
Rafal.Gaweda
For those who wants to play with it in Excel - attachment
(for nodes only)
Rafal Gaweda
Message 42 of 47
Thanks Rafal!
If I may add one detail to rounding coordinates up. (my recent experience)
I had a model with sloped roof truss. It was created on imported AutoCAD dwg.
Node coordinates were a big mess.
Ok, I used the add in, worked perfectly,
BUT
As roof was sloped, the middle nodes (those between first and the last nodes on the roof slope) went out of a plane, so local view didn't show elements correctly.
(Detalied correct to a plane solved the problem.)
So, all of you guys using this great add-in, be careful rounding everything up when you have something that needs to be collinear.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 43 of 47
in reply to: Rafal.Gaweda
It works, Very Helpful.
Message 44 of 47
mikepiT9JX4
At first, thank you very much for this API, it's very useful.
Unfortunately, after updating to Robot 2021, it does not work.
I'm not a VBA specialist, but I think the bug is somewhere in Excel itself.
When trying to update nodes after rounding them up, I get the message: "not a value in cell $D$9".
I have tried many times on different models - still the same error.
Does anyone know the solution to the problem?
Message 45 of 47
Rafal.Gaweda
in reply to: mikepiT9JX4
Hi @mikepiT9JX4
This warning has nothing to do with Robot.
Check windows settings decimal separator: comma vs dot.
Rafal Gaweda
Message 46 of 47
mikepiT9JX4
Yep, now it's works, thanks!
Message 47 of 47
Continuing topic:
Neither the built-in Robot tools (detailed axis correction) nor several API macros uploaded here work in my case.
API macros work with rounded coordinates, but Robot makes no changes.
What to do to correct the garbage in the next decimal places of the nodal coordinates (for all selected nodes, cladding, panels) ?
I set the maximum available precision in the job properties, but it has no effect.
I picked it up through "suspected" zero forces from the cladding loads - see below.
Technology Administrators
