Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Rounding up coordinates (API)
46 REPLIES 46
Message 1 of 47
Rafal.Gaweda
7939 Views, 46 Replies
I am attaching small addin (private, not ADSK) for rounding up coordinates in Robot
You can add it to add-ins menu:
- as dll (the fastest method of getting results from robot) basing on dll_1.zip from this thread starting from point 13
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Creating-DLL-for-API-and-making-it-available...
- as exe
or by running exe
It seems to work OK.
Rafal Gaweda
46 REPLIES 46
Message 2 of 47
Does this add-in applies to node coordinates only or contour panel points are also included in the rounding up?
Message 3 of 47
it will round up everything.
Rafael Medeiros
Message 4 of 47
igos
in reply to: Rafal.Gaweda
Hello, Rafal
Thank you for the solution. Unfortunally, it doesn't work on my PC (not exe, nor dll). OS is Windows 7 x64, RSA 2013 SP1.
I have obtained this error (please, see file error.png)
Log of exe error in file LOG.txt
If you need any additional info, please, let me know.
Thank you in advance!
_________________________________________
https://ru.linkedin.com/in/igor-saltykov-8a68b726
Message 5 of 47
Rafal.Gaweda
in reply to: igos
Igor,
Try this:
Start Command Prompt as Admin (from rigth hand mouse menu) then unregister and register robot exe as decribed here:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi... - message 8/9
Rafal Gaweda
Message 6 of 47
igos
Rafal, thanks a lot for your support!
Message 7 of 47
tony.ridley
in reply to: igos
Rafal,
I have Robot 2012 and 2013 installed on my PC.  I installed your add in and it works OK on 2013, but when I try to use it on 2012 I get the following error......................
Is this because the add in is already "registered" to 2013?
Tony
Message 8 of 47
Rafal.Gaweda
in reply to: tony.ridley
Can be. Please register v 2012
(command line must be run in Admin mode: message 6 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-error/m-p/3518984/highlight/true#M5791)
Rafal Gaweda
Message 9 of 47
dc
Observer
I downloaded the roundingup.zip nad run add-ins in robot , it listed on add-ins, but clicked it do not run.
Mike
Message 10 of 47
Rafal.Gaweda
in reply to: dc
Example movie: http://screencast.com/t/CFsS8hljU9Ik
Sometimes click twice on Round Up button
Rafal Gaweda
Message 11 of 47
Hi dear RG_Adsk
Can we develop some one-click installer for Robot addons?
I already have similar solution for Revit Add-In Installer
Need to replace tld.bat with automatic dll registration from installer.
Message 12 of 47
Yes, you can
Remember to register dll if you want to install dll
c:\Windows\Microsoft.NET\Framework64\v4.0.30319\regasm.exe /tlb /codebase roundup.dll
Rafal Gaweda
Message 13 of 47
Rafal.Gaweda
BTW: do you want it in your language version? If so - can you compile VS 2010 project?
Rafal Gaweda
Message 14 of 47
Yes, I know. I made my own tiny addon which create closest nodes between two uncrossing bars, very useful to link then by rigid links. I use you manual to prepare addon in Robot, thanks.
I already use you RoundUP, and I can translate it to russian (must be useful for some russian users).
I have one question for installer - how to find proper regasm in any computer?
For example
1) C:\Windows\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe /tlb /codebase
1) F:\Windows\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /tlb /codebase
Maybe some system variable?
Message 15 of 47
OK, I will prepare and send you VS project to translate
For example
As far as I remember for 32 bit system you can use ordinary regsvr32 ; for 64 ...Framework64\...\RegAsm.exe
Rafal Gaweda
Message 16 of 47
Rafal.Gaweda
Now - rounding Up or Down in attached exe.
Rafal Gaweda
Message 17 of 47
t.sautierr
Great ! works perfectly with RSA 2013 !
Message 18 of 47
YarUnderoaker
in reply to: t.sautierr
No work. I get a message box with "Robot not started" with opened Robot and without.
Path to my Robot F:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE
Message 19 of 47
Message 20 of 47
Rafal.Gaweda
Example movie how to make translation http://screencast.com/t/KRpXFwaoRf8
(Replace strings in Value column)
Rafal Gaweda
