Discussion Groups
Robot Structural Analysis
Valued Contributor
YarUnderoaker
Re: Rounding up coordinates (API)
03-22-2013 10:53 AM in reply to: Rafal.Gaweda
Okay, I will make it. Also I will try to make installer with selecting language.
Please use plain text.
Valued Contributor
YarUnderoaker
03-23-2013 08:51 AM in reply to: Rafal.Gaweda
Unfortunately I don't see any localization resources in project inside RoundUpDown_2lang.zip
I can make it myself but it's will be more simply with ready resource.
Product Support
Rafal.Gaweda
03-25-2013 02:23 AM in reply to: YarUnderoaker
My mistake.
Correct project attached.
Rafal Gaweda
Valued Contributor
YarUnderoaker
03-25-2013 03:20 AM in reply to: Rafal.Gaweda
That okay.
Valued Contributor
YarUnderoaker
03-30-2013 04:09 AM in reply to: Rafal.Gaweda
I made it, check please
Valued Contributor
mgaafar
04-04-2013 02:38 PM in reply to: Rafal.Gaweda
Rafal, I found small bug, it seems there is rounding error or defining data. in my case the numbers were ok but the new rounded numbers contained extra decimal.
Product Support
Rafal.Gaweda
04-05-2013 07:05 AM in reply to: mgaafar
Try this one.
If still not correct please send me at least part of this model with these nodes.
Rafal Gaweda
Valued Contributor
mgaafar
04-05-2013 08:28 AM in reply to: Rafal.Gaweda
Thanks Rafal, the bug is fixed and it is working fine now.
Valued Contributor
mgaafar
04-05-2013 05:08 PM in reply to: mgaafar
Sorry Rafal, I found something else that is not consistant.
Roundup2.jpg: Y-coordinate at last point was rounded up but the other ordinates changed from 10.210000 to 10.22 while the tolerance is only 0.01?
http://www.screencast.com/t/2Fe2nxr1M5L
Please review, also may be it will be more useful if "Other objects" deal with rounding structural axis coordinates as well.
thank you very much for your help.
Product Support
Rafal.Gaweda
04-08-2013 01:03 AM in reply to: mgaafar
INteresting.
Please send me such robot file.
Rafal Gaweda
