Please is there somebody who can help me with Robot steel API. I would like to define member type by API, but I don't know how to define "additional sets of member parameters". See picture below.
And my source code:
RobApp = New RobotApplication RobApp.Visible = True Dim MTData As IRDimMembDefData Dim MTParam As IRDimMembParamsE32 Dim Label As IRobotLabel RobApp.Project.Structure.Labels.Delete(IRobotLabelType.I_LT_MEMBER_TYPE, "example") Label = RobApp.Project.Structure.Labels.Create(IRobotLabelType.I_LT_MEMBER_TYPE, "example") MTData = Label.Data MTData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, 1) MTData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, -0.7) MTParam = MTData.CodeParams MTParam.BuckLengthCoeffY = 1 MTParam.BucklingDiagramY = IRDimBuckDiagramE32.I_DBD_E32_PINNED_PINNED_1_0 MTParam.BracedY = False MTParam.BucklingCurveY = IRDimBucklingCurveE32.I_DBC_E32_CURVE_B MTParam.BuckLengthCoeffZ = 1.43 MTParam.BucklingDiagramZ = IRDimBuckDiagramE32.I_DBD_E32_PINNED_PINNED_1_0 MTParam.BracedZ = False MTParam.BucklingCurveZ = IRDimBucklingCurveE32.I_DBC_E32_CURVE_B MTParam.TorsBuckOn = True MTParam.LateralBuckling = False MTData.CodeParams = MTParam RobApp.Project.Structure.Labels.Store(Label)
Thanks in advance
Solved by Rafal.Gaweda. Go to Solution.
Dim Fire As IRDimFireResistE32 Set Fire = MTParam.FireResist Fire.Active ..... Dim THW As IRDimThinWalledE32 Set THW = MTParam.ThinWalled THW.Active .... Dim ComplexS As IRDimComplexSectE32 Set ComplexS = MTParam.ComplexSect ComplexS.Active ..... MTParam.RelLimitDeflUy = 200 MTParam.RelLimitdeflUz = 200
Yes, but it doesn't work. Probably I'm doing somewhere mistake.
Here is my source code (VB.net):
Imports RobotOM Public Class Form1 Public RobApp As IRobotApplication Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click RobApp = New RobotApplication RobApp.Visible = True Dim MTData As IRDimMembDefData Dim MTParam As IRDimMembParamsE32 Dim Label As IRobotLabel RobApp.Project.Structure.Labels.Delete(IRobotLabelType.I_LT_MEMBER_TYPE, "example") Label = RobApp.Project.Structure.Labels.Create(IRobotLabelType.I_LT_MEMBER_TYPE, "example") MTData = Label.Data MTData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, 1) MTData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, -0.7) MTParam = MTData.CodeParams MTParam.BuckLengthCoeffY = 1 MTParam.BucklingDiagramY = IRDimBuckDiagramE32.I_DBD_E32_PINNED_PINNED_1_0 MTParam.BracedY = False MTParam.BucklingCurveY = IRDimBucklingCurveE32.I_DBC_E32_CURVE_B MTParam.BuckLengthCoeffZ = 1.43 MTParam.BucklingDiagramZ = IRDimBuckDiagramE32.I_DBD_E32_PINNED_PINNED_1_0 MTParam.BracedZ = False MTParam.BucklingCurveZ = IRDimBucklingCurveE32.I_DBC_E32_CURVE_B MTParam.RelLimitDeflUy = 200 MTParam.RelLimitdeflUz = 200 MTParam.TorsBuckOn = True MTParam.LateralBuckling = False Dim MTThin As IRDimThinWalledE32 MTThin = MTParam.ThinWalled MTThin.Active = True MTThin.TypeOfForming = IRDimThinWalledFormingTypeE32.I_DTWFT_E32_ROLLED MTData.CodeParams = MTParam RobApp.Project.Structure.Labels.Store(Label) End Sub End Class
Everything seems to be OK, but only additional sets of member parameters is not checked (Thin-walled sections).
I'm sending simple VB.net project in the attachment. After click on button I want to set member type parameters.
Best regards
Dim MTThin As IRDimThinWalledE32 MTThin = MTParam.ThinWalled MTThin.Active = True MTThin.TypeOfForming = IRDimThinWalledFormingTypeE32.I_DTWFT_E32_ROLLED MTData.ThinWalled = MTThin ‘ this line missing MTData.CodeParams = MTParam RobApp.Project.Structure.Labels.Store(Label) End Sub
Hello @Rafal.Gaweda ,
I'm trying to activate thin wall using that solution in vba but to no avail. Can you please provide some insight?
Dim RdimLabelData As IRDimMembDefData
Dim RDimMembParams As IRDimMembParamsE32
Set RLabel = robapp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "Pannes")
Set RdimLabelData = RLabel.Data
Dim L As Double
L = coordY(2) - coordY(1)
Set RDimMembParams = RdimLabelData.CodeParams
RDimMembParams.BuckLengthCoeffY = 1
RDimMembParams.BucklingDiagramY = I_DBD_E32_STIFF_STIFF_0_5
RDimMembParams.BracedY = False ' Sway
RDimMembParams.LateralBuckling = False
RDimMembParams.BuckLengthCoeffZ = 1
RDimMembParams.BucklingDiagramZ = I_DBD_EC3_INTERNAL_BRACINGS
RdimLabelData.CodeParams = RDimMembParams
RdimLabelData.SetIntPtAddOption I_DMDIPDT_BUCKLING_Z, I_DMDIPOT_MANUAL_COORDS, 1
RdimLabelData.SetIntPsCoordValueType I_DMDIPDT_BUCKLING_Z, 0
RdimLabelData.SetIntPtAddOption I_DMDIPDT_LBUCKLING_U, I_DMDIPOT_MANUAL_COORDS, 1
RdimLabelData.SetIntPsCoordValueType I_DMDIPDT_LBUCKLING_U, 0
RdimLabelData.SetIntPtAddOption I_DMDIPDT_LBUCKLING_L, I_DMDIPOT_MANUAL_COORDS, 1
RdimLabelData.SetIntPsCoordValueType I_DMDIPDT_LBUCKLING_L, 0
If L > 8 Then
For i = 1 To 3
RdimLabelData.SetIntPtValues I_DMDIPDT_BUCKLING_Z, 1 + i, 0.33 * L * i, 1
RdimLabelData.SetIntPtValues I_DMDIPDT_LBUCKLING_U, 1 + i, 0.33 * L * i, 1
RdimLabelData.SetIntPtValues I_DMDIPDT_LBUCKLING_L, 1 + i, 0.33 * L * i, 1
Next i
Else
i = 1
Do While (0.5 * L * i) <= L
RdimLabelData.SetIntPtValues I_DMDIPDT_BUCKLING_Z, 1 + (i - 1), 0.5 * L * i, 1
RdimLabelData.SetIntPtValues I_DMDIPDT_LBUCKLING_U, 1 + (i - 1), 0.5 * L * i, 1
RdimLabelData.SetIntPtValues I_DMDIPDT_LBUCKLING_L, 1 + (i - 1), 0.5 * L * i, 1
i = i + 1
Loop
End If
' Deflection
RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 200
RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
RdimLabelData.SetDeflectionYZ I_DMDDDT_DEFL_Y, 1
RdimLabelData.SetDeflectionYZ I_DMDDDT_DEFL_Z, 1
Set MTThin = RDimMembParams.ThinWalled
MTThin.TypeOfForming = I_DTWFT_E32_ROLLED
robapp.Project.Structure.Labels.Store RLabel
Set RLabel = Nothing
Much appreaciated for any help!
Thanks, Ana
